The Latest Notice
Notice on downloading of NTSC/PAL Multi software Now, the NTSC/PAL Multi software for IRCI-5400 and F1-ACE are available. You can get it by contacting your local dealer. At this time,you should check the system ID of your receiver at the "Status" menu. HUMAX receivers have different system ID according to the model name and hardware structure. You should download applicable software according to your system ID. And please be aware of that the existing system ID would be changed into a new one after downloading. The 0016.xxxx of IRCI-5400 is changed into 0025.xxxx and 0031.xxxx of F1-ACE is done into 0073.xxxx The rear 4 digits can be 0000,0200,0400 or 0600
